Wow you do like "Orange" don't ya.
That's where the name came from, originally on the Mach1Registry and it's just stuck. I never in a million years thought I would've liked an orange car but I absolutely loved that ride.
Just some background info on the car-
Thats one of 12 hundred something produced in Orange (734 with manual trans), less than 16000 over two years in it's limited run for all colors and trans combos. Orange was only available in the '04's.
Mach 1's had their own interior, dash and motor; not shared with any other Mustangs.
All aluminum motor and heads with 10.5+:1 compression.
The hood scoop is functional, tied into the air intake system.
I've had the car over 140 but I wussed out on pushing it anymore, stock it's capable of 155-160 before aerodynamics rears it's ugly head.
0-60 in under 5 seconds, 1/4 in 13 flat with a capable driver.....stock.
Not too bad for a N/A car.
Edit to add: The hoodscoop is cast aluminum using the same casting as the original Mach 1's.
