You better have a very strong roof because 2000*8.5=17,000 lbs of water without the weight of the tank etc..
That pressure should be, assuming a 10 ceiling, 10 + 14=24*.433= 10.39 psi when the tank is filled to the max and less as water is used out of the tank. That also assumes the outlet of the tank is on the floor of the building.
