Michaela521
How would a typical installer tackle this installation. I have a well that I would like too install a pressure tank on. I live in a place that has a required burial depth of below 6 feet. The room inside where they would typically install the pressure tank where there is a drain located and because the well is located right outside from here about 40 feet (laundry room) has a deck built on the house. How would they manage to do this. Would the deck have to be removed? The house is about 4 feet in the ground. Would they have to remove the deck, dig under the house, break up a section of concrete and run the pipe inside of the laundry room? Do they just use heat tape and not have to dig down that far? Please help me on this one. Thanks
