Gpace1
Retired
I am having what seems to be a well pressure problem. It is ONLY evident when the lawn sprinklers are on, so far. When any zone is watering, the pressure starts out good, then gradually drops to a trickle. This will occur even when no other water is running. The pressure switch cuts on and off correctly. Seems all in house systems are working correctly but we never run water in house as much as the sprinklers. I do have a Pumptec installed. (Thank God) I believe if the pump screen were clogged, the low pressure would be evident immediately. If the pump were gradually weakening, wouldn't the Pumptec cut it off? How long will a pump run dry before Pumptec cuts it off? OK, maybe the well is OK and I am jumping the gun. Hopefully it's the sprinkler system. Can a sprinkler pressure regulator cause this? Or maybe a big leak that the pump can't keep up with?
PS. We are in Austin Texas and we are in an exceptional drought. I am in the Trinity aquifer if that helps. Have no idea what my static level is.
Thanks for any help.
