What is this stem?
Jechow
British Columbia
Who makes this steam and is it still available for purchase?
Did you find it lying there like that¿ Surely the fixture had a manufacturer printed on it. Or the stem has some tell tale letters and numbers. I would eye it suspiciously if it just showed up like that and sat there unresponsive to questioning.
I'll tell you right now without looking for a replacement that this did not come out of a quality of faucet worth repairing. I would venture a guess that you will not be able to find a replacement stem. My guess it it was found in a trailer. I would recommend upgrading to a better quality faucet.
Yep, buy them for 6 bucks a piece or 5 if you buy the case. And yes, I do use them on mobile homes for two reasons. # 1 they are cheap and # 2 they are the only thing I have found that will mount solidly on the 8 dollar plastic sink. No point in putting a Rolls Royce hood ornament on a Yugo.
Do you know the name of the manufacture of this stem?
I would like to replace my existing stem as it leaks.
I get them from Compton products out of NY. But you can probably buy another faucet for the same money.
Unscrew the stem from the nut - might just have an o-ring in there that you can replace and reuse the parts you have.
Use plumbing grease as lube.
I discovered that the manufacture of my stem was Moen. I contacted Moen and they said that the cartridge was from a Chateau faucet that is no longer available. I was wondering if anyone knew of a shop that would have discountined Moen cartridges?
Thanks.
Moen stem double handel.In 20 yrs of repair Moen faucets this the only stem that I have ever seen.
  • _MOEN_001224_Double_Handle_Faucet_Cartridge_Kit__68774.1292495571.1280.1280.jpg
quote; The Larsen part number is S-164-3...
I'll take your word for it, and will have to, because no matter how far back I go in the Moen parts books I find NONE which use a "splined" stem or handle.
Back in the day, you could find Moen centersets in clampacks at K-Mart that used that stem. They were less pop-up, all plastic, and you could get them in many beautiful colors. At the time I wondered why Moen would put their reputation on the line with such junk. Probably cost some clever guy his job. All swept under the rug now, though. (They may also have been sold as Stanadyne.)
