Basic wax-ring question
brad_j
Having been to Home Depot last night, there are a plethora of wax rings:
- your basic standard wax ring.
- the oversized wax ring.
- the reinforced wax ring with some plastic actually in the wax.
- the waxless wax ring.
- the extended wax ring.
The guy at home depot said to get the oversized reinforced wax ring because it is designed for flanges that are installed properly AND for flanges that are a bit low (1/4" to 1").
Any thoughts?
Redwood
On a properly installed closet flange I use a regular wax ring.
Infact I rarely use anything else, seeing as in the case of an improperly installed closet flange I usually make corrective measures to the flange...
Avoid those with the funnel...they tend to cause more problems than they create. If you don't get things perfectly aligned, you can end up with that funnel collapsing and giving you all sorts of grief. If the flange is low, best to raise it or use flange extenders, but a lot of people have success with a thicker ring.
Tanker
NY
I've been using the one with the funnel for years thinking that it's the better one. What kind of problems does the funnel cause? So after adding a ceramic tile floor just a regular or thick wax ring without the funnel is the best bet?
Cwhyu2
Consultant
Cincinnati OH
The funnel causes a restriction,use the thick wax or as Mr Ratz said sta put
putty,used them both and they work fine,but with sta put you have form
the ring your self.
Gary Swart
Yakima, WA
I think you must understand that when we say the wax rings with funnels cause problems, it should not be take that every use will create a problem. The real point is, you don't get any benefit from one, but you do get a potential for a problem. We sometimes tend to overstate things.
Tanker
NY
I don't see the thick rings without the funnel in local stores by me, can it be pulled or cut out? Maybe a supply house would carry them.
Depending on the diameter of the drain pipe and how well you center the toilet on the flange, you could cause the funnel to compress or distort and actually close up. If you install the toilet properly with the wax, and your flange is where it should be, it will last until you decide to replace the toilet.
