pressure releif valve
fredw
Agawam, MA
I just had a inground sprinkler system installed and had a separate water meter installed. The first time I used it, my house water pressure dropped. After the second time, I had no water at all in the house. The house water has a pressure releif valve because the water pressure is 125 lbs. I had the town check the house meter to see if it was okay. It was but he also took apart the pressure releif valve, cleaned it and put it back and all was well. After I used the sprinkler again, the same thing happened. After the sprinkler shuts off, I can hear a bang in the pipes. What is wrong that makes the relief valve malfunction?
