Think the motor is the problem HELLLLLLP NOW PLS
Took the pump apart to check why i t was not pumping. Cleaned out all the salt build up and put it all back together. it was pumping fine for an hour then it stopped. i didn't take much notice until the following morning and when i went to t he pump house to find out why the pump had stopped, pushed the reset button it went for about 5-1- seconds then cut out. i checked everything before i took the pump off again...took the wet end off and plugged it in. the motor wouldn't start up without a shove.
I have tried to put a pic in as an attachment so you can see where i am on the pump. I am thinking it is the bearings, but cannot get the cover off to have a look. Can you help.
