Stephen G.
- Messages
- 7
- Reaction score
- 0
- Points
- 0
We just moved into a house that was built in 1999. Had a pipe off the preassure tank to the barn blow out a 90o elbow. Fixed the 90o but have low water pressure in the house. I took a reading of a hose off the pressure tank and it reads 11 lbs. psi. The hose by the house reads 11 lbs. psi. The submersable pump gauge reads 28 - 40 lbs. psi. and the pump booster gauge reads 60 - 80 lbs. psi. We also have a areator that seems to be working correctly. Do I add compressed air to both pressure tanks or what? Thanks for the help in advance.
