Bad smell from toilet area
bobbobwhite
California
New bathrom is less than one and a half years old with all new fixtures. Bad decomposition/sewer gas smell started 2 days ago from toilet area. Crawl space beneath has no bad odor nor does the attic above, so I think it has to be the toilet wax seal, but why would that fail so soon? I've seen them last for decades. Toilet works fine but the smell is stinking up the house so I need to fix it fast as my wife is on my case bad.
Any help sure is appreciated as I can't think of any other possibilities than a failed seal. I plan to take the toilet off tomorrow to see but don't know what to do if that is not the problem. Toilet is a TOTO and of course the floor attachment on those is a pain to access. Wouldn't you just know it?
Thanks for any help.
And are we certain it is the wc¿ There was a thread laying around here recently along these same lines, turns out it was the shower.
Dead rat in wall
Exhausted all possibilities myself and called a plumber. He could find nothing wrong with anything mechanical but said he had seen this situation before with no smell in the basement or attic, no pipe leaks or sign of any leakage underneath, no pipe cracks or loose connection, no dampness, wax seal is fine...nothing.
As the smell is diminishing, he thinks it is due to a rat getting beween the walls and dying. Has had this happen in his own house plus many others. He said rats can get through holes the size of a quarter!
So, it's not always plumbing causing the bad smells. I said I would seal every hole with foam, and he said they eat that too! Use steel wool instead.
attachment.php
