Measuring Water Level in Well
I had one for about 5 years and it worked well although I didn't use it a lot. Then I quit pump work and sold it and everything else. Once in a while I'd check it's depth reading against where the wet started on the drop pipe as I pulled a pump and it was within a foot or two. I worked on submersibles mostly so I didn't get to use it through a sanitary seal but a few times.
