Our new bathroom, almost cooked
I am curious about your shower. I see that you have a sliding hand shower, as well as a standard shower head, but I don't see a diverter anywhere. Is the diverter hiding somewhere, or does your valve have that option built in and I can't see it, or did you plumb it so that both would be on at the same time?
The Valve is a HansGrohe, and it can have both shower heads on at the same time, or individually.
http://www.hansgrohe-usa.com/JP/hruh0122.pdf
Hi Terry,
Actually mine is not that model.
It's 'one or the other' with the unit we bought, the Pro/Thermobalance II valve with the 'Talis' trim kit.
The thin 'rod' hanging downwards is the volume/selector control. Turn it to 9 o'clock and the shower head is on. Turn it to 3 o'clock and the hand held is on.
The small dial in the front controls the temperature with a high limit stop that can be over-ridden for hotter temps.
Regards,
Howard
