Master Brian
DIY Senior Member
Ok, I know there is a class action suit against zurn about their pex fittings.
My question is, are the watts fittings better or has anyone had trouble with them? I thought I read somewhere they are the same and they look almost identical. Which should I use or is there a better alternative that would use the same brass crimp tool? I also thought I had read somewhere that someone said to use the Watts over the Zurn.
I have a very good friend whom builds rentals for himself and he is a licensed contractor, he says he has the zurn in about 60 of his houses and has NEVER had an issue, but he said his plumber has started using the plastic fittings.
I'm just a DIY'er with lots of construction background, and am using the PEX to update and remodel my house. I am trying to do things correct, but am also on a limited budget.
I'm not sure what the local plumbing supply house has, but they are somewhat tough for me to get to because of hours. Lowes and H.Depot carry the Zurn, another place carries the Watts brand. I also started with Zurn with a handful of connections, but am thinking of ripping them out and returning them to Lowes.
What about Watts brass manifolds? I am doing homeruns and leaving the connections in a utility room, but wasn't planning on using a manifold with shutoffs, since it's so easy to cut, splice and repair.
Thanks in advance....
