How can I increase the temp of my Mix-it valve.
Gabe
I had a new bathroom built in June. All new construction. I noticed that the hot water in the shower is not as hot as the sink. The contractor installed a new Delta mix-it valve. I turned up the temperature at the water heater as instructed by the plumber but there is no real change. What should I do to get the water temperature to increase. :confused::confused:
Behind the handle there is going to be a temp limit/ scaldguard stop. adjust it to allow the handle to turn further to the hot position
