Older Moen Push-Pull?
vavrousek
I am in the process of doing a basic bathroom remodel...I would like to know if a Moen 2353 would retro for my older Moen push-pull...valve is fine chrome is just worn (Plate, faucet...). It's wrap around shower encloser...If it sounds dumb to do that how hard would it be to change the valve, solder thru the acces hole in the encloser. Swap out for a whole new set up?? Thank you for any advice...
John V
Marysville WA
Call Moen to see if what you have has upgrade options. As far as soldering in a new valve behind the surround, it's not a typical first time DIY job.
