Modern low-flow toilets are not as prone to sweat as old fashioned high volume ones. Here's why. A low-flow toilet not only uses less water than an old fashioned one, it uses only part of the water in the tank. That means less cold water comes into the tank and since the water coming in has been sitting in the pipe for awhile, it has already warmed up. The incoming water mixes with the water that remains in the tank after flushing which is also warmed up. Old fashioned full volume toilets uses all of the tank's water and requires several gallons to refill. The means that the new tank water is much colder that that in a low-flow, and it's the cold water that causes the sweating.
