shotzie988
- Messages
- 8
- Reaction score
- 0
- Points
- 0
I just installed a new foot vale and 2 set's of line 100 foot deep to a 1/2hp deep well pump Cut in and out are set at 40/60 when I first cut the water spiket on there is great pressure the it falls off the PSI holds at about 50 when the pressure or flow slows. all I have hooked to it is 2 water sprinklers and when they both are running the height of the water spray is about 5 foot high. What can I do? If I need to buy a better pump I will but I want water to fly out real good when turned on I worry when I build a house there I wount have enough water comming in to even shower if it acts likr this now with just water sprinklers hooked to it. It is running off 110 outlet if that helps
Please send a e-mail to me at shotzie988@aol.com I'm not sure when I will get back to this site to check it
