how do I get to my foot valve?
Mick
I have a problem with my foot valve. At least that is what I was told to look at. I have 1.5 hp jet pump, I removed that and am looking down a 2" pipe with a flashlight. I took a tape measure and hit water at 18'. I do not see anything to grab a hold of but their is definatley something there. The guy at the store told me I should be able to grab ahold of a smaller size pipe and pull it right out well point and foot valve attached. Do you have any answers for me??
Thanks Mick
If you took an elbow off the top of the well to remove the pump, you won't have any droppipe or a footvalve. There may be a Bremer Check Valve at the bottom, but you don't want to remove that. If there were a Bremer in the well, it should still be full of water.
I assume you have a check valve in the pipe between the top of the well and the pump. Right?
bob...
