on02151blueline
- Messages
- 4
- Reaction score
- 0
- Points
- 0
Here is some info about the pump & motor:
A.O. Smith Model C48A94A06, SER 8G97, HP 3/4. Also on the A.O. Smith plate is: Goulds NO. J05853L. The cast iron motor adapter has part#1K310 casted into it.
I have a Goulds Jet+Plus pump that the cast iron motor adapter cracked. (I think my irrigation guy didn't drain it properly before winte
I found the Goulds ITT manual by searching for that part number and want to order one and install it. My problem is that I can't figure out how to get the motor adapter off of the motor shaft. I have found, on this forum thank you, how to remove the impeller, but now I need to remove the spring looking thing that appears to be holding the motor adapter on to the shaft.
My other question is, now that I have the thing apart, are there any other parts I should replace? This motor/pump is pretty old, installed by the previous owner so I have no idea exactly how old it is. It is only used in the spring/summer.
And my last question is, when I am looking at the Goulds ITT manual I assume it is safe to say my model is a J+,right? Under the J+ series heading on the parts listing there are several columuns, J5 J5H J7 J10, J15. How do know which columun to get my part numbers from? I would like to replace the impeller, but there are four different part numbers listed under those five columns.
Thanks in advance for any help anyone could provide me.
