Cleaning turbo torch tips?
TMB9862
How do you guys clean these out? I've got a bunch of them that either have a horrible flame or spew black gunk all over. I finally ran out of extra tips and it's now either clean em up or buy new ones. I know you can remove part of the bottom with an allen key but where do you go from there? Soak it in diesel, tiny wire brush, etc?
Filters????
I usually soak them in gasoline
How do you change a filter on one of those ????
Usually when all else fails I heat up the tip with another
torch and that will clean out all the debris and solder balls that get
inside one of them....
I never knew that their was even a filter that could be changed
Filters are on the bottom tof the tips. They come out with an allen wrench.
A tip that has hardened solder in it might require heating up to make it flow out.
