“Not to torture you - but I have designed and built many machines, and in this case would have scavenged a used compressor tank or bought a new surplus one ["Surplus Center" in Omaha] for the job.... Okay lets say the ports were wrong, I know you need a big outlet.
I would have put 1/2" or 3/4" end caps on that tubing and PRIOR to welding it up, would have drilled and tapped the 3 ports that you appear to have welded on. Or to have drilled holes, and then inserted flanged nipples through from the inside and brazed them in place. Neater, cleaner, not likely to blow out and lodge in some kids forehead. Better yet to have drilled and tapped ONE outlet and to have tee'ed for the others.
Nice silly machine [what the hell do you do with that?] and I doubt that it will ever cause a death, but I would mix some machining and more subtle welding into it. I would NEVER weld on a coupler as a port. Many of the import couplers have very weird metallurgy and you will have unknown stresses and future break points. You got yours early, as a gift. Brazing would be more predictable. But remember coupler are couplers, not tank outlets!
Did you preheat this structure while welding and cooling down? That will make a big difference in its integrity.
For what its worth dept. : I have a pressure vessel MFG date 1916, its steel with bronze cast end caps, maybe 150 gallon. The end caps are brazed on, and it will loose about 5psi per month. Never saw anything like it, but man, what a great piece of work. Dont make them like that anymore.
All that said, I would only sell that if I was dirt poor or had BIG insurance for pressure vessel construction [fat chance!]”
Thanks Raucina,
You made some good points. I did try to locate a pressure vessel that would work for this application. You are correct that the ports are wrong, and I did need a big outlet.
I needed a 1” output from the tank to the solenoid valve. I looked into paintball-gun tanks, etc. but nothing had that large an opening. Trying to modify one of those would be more dangerous than anything.
I decided the end caps were too thin (5/16”) to tap with NPT threads. If I had it to do again I would take your suggestion and use ½” end caps and tap directly into them.
The “couplers” I used are actually reducers. The fat ends don’t fit through the holes. As you suggested, they were inserted from the back and welded to the inside of the cap before the cap was welded to the tank. They couldn’t come out even if they were not welded. I agree, brazing would have been better for this job, but I wasn’t sure the strength would be enough.
If you’ll notice, all the valves are below the top of the frame, so they are less likely to get broken off. A single “T” would not allow that.
This was a big chunk of cold steel, so yes I had to pre-heat before welding.
Did anyone read my post that I saw a basketball hold 100psi before bursting on Discovery Channel? I'm sure no part of my tank is weaker than a basketball.
