Remodeling the bathroom, currently gutting down to the studs and found this.
First: The tub drain and vent. The wye on the drain pipe is rolled slightly so that the section that drains the tub is higher than the section going to the vent. I would think it should be the other way around. Should I cut that section out and redo it?
Second: If you follow the drain pipe toward the waste stack, it turns 45 dgrees to go from horizontal to 45 deg from vertical. An inch later there is a 90 ell to go from that diagonal to hoizontal and to change the direction perpendicular to the initial horizontal. Is this OK?
