lahabra
I herd that arc fault requirements are going to be expanded soon.
That depends.I herd that arc fault requirements are going to be expanded soon.
The 2008 code requires AFCI protection for ALL new 120 Volt circuits in residences. You should pull your permit before the 2008 applies in your jurisdiction to avoid that expensive stupidity.
Existing circuits usually don't fall under the new code.
You should pull your permit before the 2008 applies.
Since hard wired smoke detectors and lights are in bedrooms, will they also need ARC fault protection?
How could that possibly be?I already have my permit. I am under the impression that my job must be in compliance with current codes on the date it is inspected, regardless of when the permit was issued.
