When it rains it pours...now the circuit that my refrigerator is connected to went out. I had a large Foreman grill and coffee pot on the same circuit going at the same time.
I went to the breaker box figuring that the surge turned off the switch, but not the case. I went outside to check the box by the meter and there's just one main switch.
I turned off then on the effected circuit, but still no power.
I should add that there are about seven outlets on this circuit, says '20.'
The previous owner replaced the breaker box before moving because the entire electrical system had gone out.
Any ideas what the problem may be?
Is there any way to reset it??
Thanks.
Thanks.
