ice maker hose problem
30all
I installed a leak-proof (bought at HD) steel braid 1/4" hose to connect ice maker in refrig. For some reason, no water flows through hose to refrigerator. It looks like water is stopped by 'leak proof' lock at water supply even I don't have a leak downstream, How I can fix it??
Gary Swart
Yakima, WA
Are you using a saddle valve to tap into you water supply. If so, that's most likely the problem. Most of us throw those saddle valves away and use a ball valve with adaptors to attach copper tubing to go to the ice maker. Another possibility is that a gasket in the end of the hose is messed up and blocking it.
30all
I did not use saddle valve, the hose is connect to 1/4" ball valve stop soldered to 1/2" copper. I'm sure is has something to do with that leak proof thingy where blocked water flow.
E
elvisclock
Guest
If it is a flood safe hose than that is most likely the problem. It seems that they are prone to the problem like you are having/
hose
If you used a flood proof hose, you must turn the valve on slowly, or it will think the hose burst and shuts it off. To get it flowing again you have to turn off the valve, then loosen the hose from the valve to relieve the pressure, then turn the valve on very slowly.
