Hi
The pressure switch on my well burned out over the weekend, sticking closed, and ran the water pressure up to around 135 psi, in turn blowing the fill valves on both toilets, and the ceramic seals in my kitchen faucet. From what I can tell, the pump ran like this all night before it was discovered, as I flushed the toilet, went to bed, discovering the problem early next morning, and my septic system was sluggish, so Im sure that it ran out quite a bit of water. The pressure switch was replaced, and now Im noticing that when using water, the water pulses, and I can see the lights flicker up and down about every 2 seconds as if the pump is starting and stopping. Everything seemed fine for the first couple of days before I noticed this. The driller thinks that the pressure blew the bladder in the tank. Does this sound right? More info on the system if it helps....The pump is a Goulds 10EJ10422 series, one horespower 2 wire, and the pressure tank is a Hydro-pro model V-200-B burried tank, which is burried in the ground right beside the well. I cannot read the paperwork clearly enough to determine whether it says that the tank is an 82 gallon, or a 62 gallon, but it does show a 20.1 gallon drawdown. The entire system was installed in Jan of 1993, and everything is original except for the pressure switch which has been replaced once before. The well serves a total of 3 houses. Thanks in advance.
