OK, you had no water, then suddenly the next morning you had water? You turned on a faucet, did you leave it open, you flushed, or what?Originally Posted by pandtmoore@msn.com
Do you have a water filter, or water softner? If so put them in bypass.Originally Posted by pandtmoore@msn.com
What did it change? Is the pump pumping up to the cutoff pressure?Originally Posted by pandtmoore@msn.com
Turn off the pump, drain the tank, measure the air pressure in the bladder., set it at 32/33psi ... shouldn't you hear water noise in a water tank? Do you mean you heard gurgling noises? Is your pump cycling a lot, i.e. does it pump up to cut off pressure fast?Originally Posted by pandtmoore@msn.com
Rancher
