I recently bought an 85 yr old house and the hot water would turn brown/rusty after it ran for a while. I replaced the 17yr old hot water heater about 3 months ago, and the hot water was clear for a while and I thought I solved my problem, but now I see it turning brown again as it gets to the end of the hot water. And it's not just slightly tinged - if I let it run long enough, my bathtub fills up with water that looks like iced tea!!The cold water is fine and crystal clear. What could be causing this? Thank you.
But here's what I noticed - on the floor near the boiler where some water was drained there is all this rusty sediment on the floor. There's a feed to the boiler from the water tank - could rusty stuff from the boiler somewhow be flowing back into the water tank? I shut off the feed to the boiler for the last 2 days and after initially flushing out the water heater, I haven't seen any more brown/rusty water out of any of my faucets yet. Could this be the culprit?
