I have a 3" PVC sewer line connecting to toilets, showers, etc. There is also a seperate 2" sewer line that handles the kitchen sink (with garbage disposer) and d/w. The two sewer lines currently exit on oppisite sides of the building.The separate sink line exists because there probably was a seperate drainage pit for the sink prior to sewers being installed 25 years ago. Because the 2" pipe from the kitchen sink to the main sewer is a long one, it gets clogged. I'd like to re-direct the 2 inch pipe from the kitchen (in the crawlspace ) and connect it directly into the 3" sewer line (a much closer, direct path).
Question: I will have to cut into a section of the 3" sewer pipe run, and insert the appropriate fitting to connect to the 2" pipe. How best to do this? Is there a PVC slip joint fitting for 3" pipes? Or, is a no-hub clamp connector an option for splicing into the 3" line?
