I am installing underfloor heating in a few rooms. Coming from the oil burner I have a two 3/4" copper pipes running, one supply and one return. Coming off of these pipes I will have three separate runs to PEX tubing, one for each room. I want to be able to control how much water (and thus heat) is flowing to each of the three rooms, so I want to put a shut off valve before each leg of PEX. There is a thermistor in the floor of only one of these three rooms. I was planning on just putting a cutoff valve on the supply side leading to each PEX run. But now I am thinking, what if I have a problem with one of those three runs (like a leak)? Am I beter off putting in valves on both the supply and return of each run, or will just one valve per run do it? I am not looking to over engineer this thing.
