Results 1 to 9 of 9
Thread: Bathroom Sink Leaks
    Default Bathroom Sink Leaks
    Our single handle bathroom sink faucet leaks on the hot side. It's a steady flow so the hot side was turned off. How is this fixed?
    Plumber Cass's Avatar
    Nov 2005
    Depends on the brand as far as what parts you need to fix it. Do you know what brand of faucet it is? Can you post a pic of it if you don't know?
    Quote Originally Posted by Cass
    I forgot the brand, but here's the picture.
    Try popping off the lever and valve and cleaning the o-rings.
    (important note: I'm not a pro)
    Quote Originally Posted by prashster
    How is it popped off? That's the hurdle.
    Nov 2005
    Is there an allen screw under wher you grab the handle?
    I'm a bit confused. Is it leaking on top of the sink where the handle lever screws in, or is the hot water dripping inside the sink from the spout?
    Once you get the handle off, look to see if there is a cartridge that pulls out--like a Moen. or a ball-like valve stem--like a Delta.
    Found it! A little plastic doodad, half blue, half red, had to be popped off to find the pit where a philips head screwdriver fit. It's a ball type faucet and the left (hot) washer was nicked. Anybody know how a practically new faucet could get a nicked washer? Off to the hardware store I go....
    Thanks....
    Yep.. trash under the washer when assembled or got in there after installation because water line was not flushed out before connecting to sink. I just replaced a ripped up faucet washer in a brand spanking new house.
