I noticed an issue with my 3-1/2 year old well about a month ago. I have a 400' deep well, with a Goulds 7GS10 1 HP submersible pump.
Intermittently, when the low cut-on pressure of 40 psi was sensed by the pressure switch, activating the pump, an audible surge/chatter was occurring at the pressure switch with the contacts cycling back and forth. It almost sounds airbound. I replaced the 40/60 pressure switch and while doing so made sure the air pressure in the expansion tank was set correctly (38 psi) after draining down the system.
If running the water when pump comes on now, the water pressure in the house drops to zero. The only way to overcome this is to shut the open faucet/valve and wait for a few seconds. Turning back on and everything is fine. Mostly happens with hot water.
I tried another switch since I thought that one might be defective and verified the nipple is cleared of blockage.
I was reading about upthrust usually caused by defective check valves. Is this possible? Any other thoughts?
I am new to this forum but from what I read, it seems like this is the place to go for advice.
