All of the installation instructions I've read say that the discharge from a T&P valve should be 6" from the floor drain. What do people do if they don't have any floor drains in the house? Is it okay to route this outside? (My guess is no, you might never notice it is leaking?) While the basement floor is concrete, and a discharge wouldn't necessarily create immediate problems, what's the best way to handle this?
If the boiler and WH tank are in a pan, and the T&P discharges into the pan, can you use a condensate pump to get rid of the water? Will a normal pump handle the (likely) high temp? I'm sure it wouldn't handle a full-fledged discharge of a fully opened valve, but for the more normal leak, it would.
My fixtures will be replaced, and they've been fine just run down towards the floor, but was wondering if that is still allowed, and, if not, what will work.
