Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Thread: Direct Drain Bath Tub Question
    DIY Senior Member OldPete's Avatar
    Jan 2006
    NJ
    Default Direct Drain Bath Tub Question
    Please help me get to the bottom of this. Let me know if you need more information. Thanks!
    I have this unit:
    American Standard 1599.205 which is the Overflow Drain for their whirlpools. This drain is set up for horizontal draining only. The toe-pop-up drain screws into the fitting @ the bottom of the tub and then sends it out sideways.
    What I am looking for the way to make it into a direct drain. Where, if you were sitting in the tub (yeah, silly I know) and you look at the drain in the bottom of the tub, that drain would go straight down into the trap. The overflow would be what would come in from the side.
    Here is a picture of a direct drain:
    Here is a picture of the American Standard drain that I have. If I can just get that bottom part (that the toe-drain screws into) in a Tee or a Wye or something where the top of the Tee or Wye is threaded and has the flange to support the gasket to create a seal I'd be good:
    Basically I just need to change that "Drain Ell Assembly" into a "Drain Tee (?)" or something of the sort. (I think.)?
    Thanks for taking the time to read and let the picking of the brains begin!
    Thanks again,
    Pete
    36 Journeyman Plbr rudytheplbr's Avatar
    Sep 2006
    Ketchikan, Alaska
    Default Re: direct drain
    It looks OK to me, I don't see any reason to change the Waste and Overflow as set. The trap is most likely under the drain and as such doesn't require any adjustment.
    You didn't state a reason for the change out, but if the old one quit working, and the new one is the only one available, You're looking at changing the trap location also, so post some pics if you can, and let us see the total scope of the problem.
    Good Luck,
    Rudy
    EAT "WILD ALASKA SALMON" IT'S GOOD FOR YOU AND YOURS
    Default drain
    It is called a "toe outlet" drain, and they are much rarer these days than they were in the 50's, but if you search you can find one.
    Jan 2006
    NJ
    Hi,
    The first pic in my original post if the way I need the second pic to look. In other words, if you look closely at the first pic, you'll see that the trap connection point is directly under the drain. If you look at the second pic you'll see the trap connection is directly under the over-flow.
    I need to be able to convert the second picture to connect to the trap when the trap is under the drain, not the over-flow.
    Thanks for all the quick replies,
    Pete
    Plumber Cass's Avatar
    Nov 2005
    If you can't find one in your area PM me and I can get you one and send it to you.
    Jan 2006
    NJ
    Quote Originally Posted by Cass
    OMG! Thank you so much for the offer Cass. Question. Before I trouble you, do you know what it is called so I know what to look for. I'll even try and go to the plumbing supply, but to be honest, I don't want to look like a total moron.
    Thanks again!!
    Pete
    Nov 2005
    hj posted it, a toe outlet drain.
    Jan 2006
    NJ
    Ah, darn, I know that was too easy. I have that part. That's not the problem. The problem is with the part that the toe outlet screws into. In my second pic it screws into what they call a "Drain Ell" -- I need that to be a "Tee"... so that it looks like the first pic.
    Nov 2005
    They are fairly expensive due to the fact that they don't make many because there is so little call for them..
    Nov 2005
    I can get you the tub waste that looks just like the first pic. there is no T in it. Thats all I can get. Thats all that they make in that style.
    Jan 2006
    NJ
    Ah! Excellent! Yes! Just like the first picture -- now... can I screw my male toe-drain into the drain assembly on that?
    (Thanks again!)
    Jan 2006
    NJ
    Ahhhh... looks like they make her in plastic too! We're getting closer!
    Edit: Sorry I goofed and downloaded the wrong picture... but the correct one can be found here:
    http://www.oateyscs.com/bath_waste/b...ng_catalog.pdf
    on page 50.
    Here's the correct description:
    Full Kit Plastic Tubular, Uni-Lift for Direct Drain*
    P8227D Uni-Lift bath waste with white polypropylene direct drain and 10 041193026712
    plastic tubing rough-in, 2-hole top ell and 1-hole faceplate, retaining
    clip to secure bath waste to tub, blue top ell washer, 1-1/2" waste shoe,
    1-1/2" brass Uni-Lift drain unit with washer seal, PVC slip joint tee,
    (2) wing nuts, (2) poly washers, bottom ell washer, chrome trim, boxed
    with individual UPC on package
    A8227D Same as Above, Black Polypropylene w/ ABS Tee
    Jan 2006
    NJ
    See above... (remember, that pic is wrong... but I added a link.) -- basically the same as what is in my very first pic, but only in PVC.
    Jan 2006
    NJ
    Nice Hi-Res Pic...
    Or... you could make your own with this:
    and a tee... I think I like the idea of the first one... now I just have to track one down.
    Default drain
    You do not convert your drain to a toe waste, you buy a toe waste and install it, although you can mix and match the parts for the two if necessary.
