Not sure how to answer you, since the Kerdi drains all show it being connected to a PVC trap and riser. That would not work with a cast iron pipe because there would not be any way to connect the two materials without having a leak. If that is the only connection Kerdi uses, then you have to break the concrete, cut off the cast iron riser, couple on a piece of PVC cut to the right length, and then glue on the Kerdi drain.
Now the unfortunate task of telling my husband that it's time to get a professional.
