Sounds like the Diverter valve in the wall is messed up and either needs replaced, or some work on it if you can fix it without the replacing. If not able to fix, your "easy fix" may end up being a long fix due to if the valve, you will end up doing some construction work on the wall to replace, and possible plumbing work.
