We have an older shower (no real guess on the age) that was leaking a little bit into the guest room downstairs. I pulled open the dropped ceiling in there, shut off the two valves leading up into the shower, and proceeded to take the bugger apart. While doing so, I found the source of the leak: the hot/cold mixing valve (it's a single-valve/single-knob system with the shower/faucet switch on the tub faucet). So I replaced the rubber o-rings, put things back together, threw open the shut-off valves, and nothing. barely a dribble coming out of the shower. Bathroom sink faucet and water pressure throughout the rest of the house is just fine, but nothing coming out of the shower. So I removed the mixing valve entirely and opened the shutoffs again. Nothing, again.
Thinking that it was a matter of the shutoff valves maybe getting stuck closed, I turned off the house main and popped those off. They're definitely old, but things looked OK, and the rubber rungs on the ends of the stoppers were still attached to the screws. (At least, as best as I could tell). So I put those back in, took out the mixing valve entirely, and turned the house mains back on. No water, even with the mixing valve completely removed, again.
This situation has confounded me. Where could the problem be? Could I have screwed up the mixing valve in my fuddling, causing the backup? Is there just a bunch of old gronk in the pipes someplace? Does my plumbing just hate me?
Any advice would be appreciated.
