Results 1 to 5 of 5
Thread: carpet panels
    DIY Junior Member ETHBilly's Avatar
    Oct 2006
    Hills of East Tennessee
    Question carpet panels
    Hello, new here. I was wanting to know more about installing carpet panels. Has anyone here done that? My spare bedroom has hardwood floors. I know, they are great and should never be covered. However the room is over a basement and the cold comes thought the floor and keeps the room chilly in the winter. I wanted something to cover the floor that I could remove in spring. I saw these carpet panels at my local hareware store. They wouldn't take up much room when I needed to store them as a long carpet roll would. Home don't have much storage space. My home was built in the thirtys so I do not store anything in the basement for fear it would be destoryed from the dampness. Anyway, has anyone ever installed carpet panels, do you like them, and are they easy to install as I have been told?
    A cheaper approach might be to try to tack up some insulation between your floor joists, if you have access to them from the basement and/or buy a couple of rugs.
    Just a little thought--there is no cold, but an absence of heat. Insulation will slow the loss of energy (heat), but not stop it. I think you might be happier with some insulation under the floor. You should be able to put up at least R-19, and more would be good. R-19 is usually about 6" thick, and your joists will be at least that deep.
    Default carpet
    I am sitting on a chair that is on carpet panels right now. Cut the edge ones so there is a tight fit and you probably won't even know they are panels after a couple of days.
    Oct 2006
    Thank you, I think I will do both. Maybe that way it should keep the room real warm in the winter and good and cool in the summer.
