yakdog
- Messages
- 1
- Reaction score
- 0
- Points
- 0
I have a small cottage that I would like to use during the winter. The cottage is not very well insulated and it only has electric baseboard heat. The hot water tank and well pressure tank are in a partial basement, which is not heated. A section of the hot and cold supply lines run from the basement, under the front of the cottage to the bathroom, directly exposed to cold air. Temperatures below zero are not uncommon here.
Rather than try and improve the insulation, wrap the pipes, and keep the entire cottage heated to prevent the pipes from freezing, etc., I was thinking of an alternative. Is there a system that would allow me to force the water in the lines back into the well, using an air compressor perhaps. What about the hot water tank and well pressure tank? I was thinking I could frame them in, insulate the "closet" and just try and heat this small space, instead of the entire basement. Would I shut off the power to the hot water tank, since the water supply would be turned off as well? I would then only need to put some RV anti freez in the traps and I would be all set until my next visit.
Any sugestions? Would this work?
Thanks.
Thanks.
