Results 1 to 2 of 2
Thread: cpvc and wrong glue
    Default cpvc and wrong glue
    I installed some 1/2 " cpvc and just realized I used the PVC Regular Clear glue by mistake. I did use the purple primer. Should I redo the work? It cured for over 12 hours if that makes any difference.
    Plumber Cass's Avatar
    Nov 2005
    Yes, There is a reason they make PVC and CPVC glue, and it is not just to sell another product. CPVC is not the same and won't hold with the PVC solvent.
    PVC = PollyVinal Chloride
    CPVC = Chlorinated PolyVinyl Chloride
    The "glue" would be a different composition to solvent weld it.
    Cut it out and change it.
