I just installed a Toto Dartmouth with G-Max. I notice if I turn the flush handle and release it right away, the water level drops only half way in the tank. Also, the bowl only fills halfway because fill time is cut in half.
However, if I turn and hold the handle for about two seconds, all the tank water drains and the bowl fills nicely.
I believe the reason for this is that the red flapper valve has a 1/2" round hole in the side (which allows water to quickly fill the flapper - causing it to drop quickly). I never had this type of flush action in my many previous (non-Toto) toilets.
Is this an intentional design (little flush-big flush) or do I have a problem? Thanks!
