Hello,
I'm getting ready to tile the bathroom and in so doing removed the toilet to reveal a bit of a mess that I'm not sure how to deal with. I removed the subfloor which was water damaged so at least I've got decent access to the area from both above and below. It's a cast iron bend. The existing brass flange was wrecked by overtightening of the toilet bolts such that it was pulled up on each side. In my overzealousness to get rid of all the damaged stuff under there, I may have caused more problems. There is a short lead pipe which is what is seen in the photo. Once the new subfloor is installed & tiled, the floor will be 1" higher than before. I hope the photos will be meaningful to those of you who know what you're looking at. The house was built in 1954 and the toilet I just removed was original. This is my only bathroom so I need to get things back together ASAP.
So, where do I go from here? Can I cut off the top portion of the lead pipe and find a fitting that will fit inside of that to which the new flange can be attached? Or do I remove everything back to the cast iron bend and find a fitting that will connect directly cast iron? Or do I pee in a pail for a few days until I can get a plumber in?
If there is any other relevant information I have left out, please let me know.
Thanks in advance,
Bryan
Thanks in advance,
Bryan
