I would not use the torque arrestor. I do not think they work, and cause trouble like your own. I just had to pull a pump back up where the standoffs caught on the casing joint lip. Cutting them smaller and some jostling when lowering got it down.
If you bought pvc perforated pipe off the shelf, likely its made for septic and drain use and is not rated for drinking water. I buy low pressure pvc rated for drinking and slot it with a chop saw or band saw in the water zone only.You can get some nasty chemicals out of pvc without a NSF rating.
