Results 1 to 7 of 7
Thread: deck
    Default deck
    I was wondering if I could put Thompsons waterproofing over the Cabots I used on the deck. It doesn't seem to be repelling the water. Thank you.
    Thompson's WS is crap. Stay with the Cabots.
    In some locales, you might have to reapply that stuff yearly. Not sure, but expect it wanted a couple of coats the first time it was applied. Double-check the instructions. Old wood can be really thirsty, and will soak the stuff up; eventually, if you apply enough, it should make it between seasons.
    I went and read their application instructions - it says one coat. My guess is, though, that you didn't apply a good one. It also says to only apply enough that can be absorbed, but it talks about spraying it on, then brushing to even it out. If you applied it too thin, it won't work properly. Did you use as much as it says? They give 'normal' coverage specs, and if you got significantly more coverage, you really didn't!
    DIY Senior Member Pewterpower's Avatar
    Jun 2006
    Tampa
    Someone need a hug????
    I could go for some hot wings and a beer, myself.
    Plumber Cass's Avatar
    If you have wiped off the excess, no pools of sealer, let it dry.
    I think you'll be okay once it gets a chance to soak in. Decking thathas seen th esun for a few years can suck up a lot.
