Results 1 to 5 of 5
Thread: Type of check valve
    Like an engineer alternety's Avatar
    Apr 2006
    Washington
    Default Type of check valve
    I am specifying some check valves in my new water system (well source). They are used to keep water from moving backwards through the centrifigul pressure pump and from flowing backwards through a filter that has its own pressure tank on the filtred side.
    I would appreciate input on wheather to use swing checks or spring loaded checks.
    Plumber plumber1's Avatar
    Aug 2005
    Florida
    There are spring loaded checks for that purpose.
    Rancher
    Guest
    Where is your centrifugal pump located?
    Rancher
    DIY Member Hardt's Avatar
    Hawaii
    Smile
    FWIW, I don't have any experience whatsoever in wells but my solar water system used a spring check valve and the rubber o-ring deteriorated to nothing and the spring probably was not at specs because of age. I had recurring problems trying to keep it working so I replaced it with a swing check valve and I don't see anything that can go bad with it... no spring, no rubber o-ring and don't see gravity going away anytime soon. It has worked flawlessly for the past 5-6 years.
