Thread: Metal straps on ABS pipe?
    General Contractor David Meiland's Avatar
    Apr 2006
    Friday Harbor, Washington
    Default Metal straps on ABS pipe?
    I bought a couple of boxes of 2" and 3" C-shaped pipe straps from Keller. When I opened them they turned out to be galv steel. I'm going to be running ABS drains and am not sure that metal straps are OK on plastic pipe. The salesman I buy from is generally right on as far as what he sends out to me, so I assume that's what he's sending everyone. What are pros using?
    Plumber Cass's Avatar
    The metal straps will be fine as long as when you hang the pipe it doesn't pull the pipe up from the drain angle.
    Apr 2006
    These would generally be used where the pipe is vertical and against a stud. I have the correct hangers for running underfloor.
    Plumber Winslow's Avatar
    Dec 2005
    Hawaii
    they will work good.
