The nozzle in the pump could be pligged up. On the Goulds shallow well pumps there is a pipe plug directly underneath the suction port. Remove this plug, and using a piece of wire, you can clean out the nozzle. Once it's clean, the wire should go in about 6" or so.
Be sure you shut the power off and drain the pressre down before you remove the pipe plug.
Ron
