Cookie said:I don't know the answer to that, I am not a plumber. But, I was told the other day, that they make, " time released ones" see, under the post, Mark up, under Plumbing. Not sure how true this is. Maybe, you could ask..
Unless we survey a statistically significant number of plumbers, we are probably only guessing at this.hj said:It is the other way around.
1 Most plumbers do NOT use the wax ring with a funnel.
2. Some plumbers DO use the one with the funnel.
I'll try that next time I use two wax rings. Although the other way has worked fine for me up 'til now.hj said:3. If you are going to use two wax rings, the one on the TOP should be the one with the funnel so it keeps the lower one without one lined up.
abikerboy said:As some of you know, I have been helping out a plumber friend who is having health problems. I learned an interesting lesson today which actually touches on another post here about a sweating tank. Homeowner has his toilet piped into a hot water line. Seems like every 8 to 10 months, he gets a leak at his wax ring. The guy who I was helping out looks at me, and says "Rob, what do you think hot water feeding a toilet does to a wax ring?" Never really gave it a thought before. Then he points out the few times when a toilet gets used sucessively, and he also points out the small amount of water that escapes the bowl upon a refill after a flush. Food for thought, huh?
Verdeboy said:So, what you're saying is that hot water is required to activate the "time release" wax rings?
