constant pressure
If you have never had "constant pressure", then you don't know what you are missing. I don't know of anyone who has had a "constant pressure" system, that would ever again be happy with the 40 to 60 varying pressure. With the old 40/60 system cycling on and odd repeatedly, the house pressure is always better when the pump is on and the pressure is increasing. The house pressure is always worse when the pump is off and the pressure is decreasing. The old 40/60 system gives an average of 50 PSI, but as the pressure drops to 40, you have 2/3rds or just a little over half the pressure you have before the pump shuts off at 60 PSI. When the pressure is at 60, you have almost twice the pressure you had before the pump started at 40 PSI. A Cycle Stop Valve will let the tank drain one time from 60 down to 40, and then holds a "constant" 50 PSI as long as the shower is on or any water is being used. A "constant" 50 PSI gives the house much better pressure than an average 50 PSI. The washing machine fills faster, the sprinklers have more force and hit exactly in the same circle every time, and the shower seems so much stronger that people tell me they don't even need soap in the shower any more, the "constant" 50 PSI just blast the dirt off of them. The CSV is the only thing I have ever installed as a pump man that the customer can easily see the difference. With the old 40/60 system it was "thanks for getting my water back to working, I guess we will see you again in a few years". With the CSV it was "I don't know what you did, but I have never had this kind of pressure in my house ever before".
With the old system, the wider you make the bandwidth (45/75), the less the pump cycled, but the more variation of pressure in the house. With a pressure regulator set at 55 PSI after the tank, the pump will still be cycling on and off and you always need more than 55 PSI from the tank (55/75) for this valve to keep 55 PSI on the house side. I don't know why anyone would want city water supply cost and taste, when they could so easily have constant city like water pressure from their own water well with much better taste and much lower cost per gallon.
40/60 or 45/75 is very detectable to anyone who has experienced "constant pressure".
