Results 1 to 7 of 7
Thread: Moen diverter removal...help
    Default Moen diverter removal...help
    I have a three handle diverter that i need to remove. i removed the handle. and then the brass nut that i thought would be the final step, but to no avail... the problem lies with the shaft of the diverter because it is plastic. i have a screw from the handle to thread into it. if that is any help. the base of the diverter is brass and i do not see another nut or anything to grab a bight. any thought????????
    Central Florida
    Call 800-BUY-MOEN for customer service. They're excellent.
    If you could post a photo that would help.
    Default diverter
    I do not think I have ever seen a Moen three valve diverter faucet.
    it is a three handle setup(hot on the left cold on the right and shower in the middle. not three valve. i just need to remove the diverter and replace it. the pic were to big of a file sorry guys
    Quote Originally Posted by elgucho
    You should be able to convert your picture file to a smaller one using this link.
    http://convert.neevia.com/index.aspx
    Choose your output file type: JPEG etc., then lower the resolution and quality.
    good news i called the 800 number for moen and they are sending me a FREE Diverter. thanks guys for the help
